| wrong gasketDecember 1 2008 at 4:46 AM | bill (Login billinstuart) |
Response to Leaky head gasket? |
| Your leak was at the intake gasket. Was the intake gasket a plastic unit with silicon rings on it? These were used on the vortec style 4 bolt intake systems, and are a very common problem. When reinstalling, they only tighten to 9 ft. lbs. or so.
A head gasket leak to a water passage will blow all the water out of the cooling system in short order. You only have maybe 14# pressure in a closed cooling system, and 2000# of compression pressure in the cylinder. Water doesn't leak into the cylinder except when the engine is shut off. |
