Leaky head gasket?
November 30 2008 at 5:14 PM
  (Login sixsixcommander)
Hello,
Looking for a little insight into coolant loss on 5.7 1988 Crusaders FWC.
Last summer my RH engine overheat alarm went off and shut down engine. After refilling coolant, I notice a slow loss of coolant. About 2 QTs every 4 hours of running. I just kept topping off so as not to run out of coolant and really overheat the enging. At the same time I replaced the heat exchanger but coolant loss continued. Then pulled all the plugs and #6 plug was very white (steam cleaned?) compared to others. I also observed bubbles in the heat exchanger while engine was running. So I'm thinking that I have a bad head gasket around the #6 cylinder. Of course this engine is the stronger of the two engines. Unknown hours and has had at least 1 rebuild. Elbows and riser were replaced last season, but did not change exhuast manifolds. During tear down there was no signs of milk shake oil under valve covers.
Last week I did a compression check on all cylinders and thought that the engine was worthy of a new head gasket and maybe rebuilt cylinder head.
1. 174 psi 2. 183 psi
3. 176 psi 4. 180 psi
5. 175 psi 6. 185 psi
7. 183 psi 8. 175 psi
After tearing down the engine I was hoping for the smoking gun of hole in the head gasket around #6 Cylinder but did not find it. I did not observe a hole in either head gasket (LH/RH cylinder heads). While also looking at intake manifold gasket I did not observe any hole or tell tale water stain trails.
1. #6 Cylinder has highest compression, (is this related to water not compressing?)
2. Should I see tell tale trails of water stains?
3. #8 Cylinder wall has staining similiar to water stains (not rusty, but discoloring of cylinder wall)
4.Could gasket be faulty without a noticable hole?
5. Some intake and exhaust valves bottoms are soot covered. Some are not and look pitted. Both LH/RH cylinder valves have this condition. Could both manifolds been bad?
Stumped,
Timmy
