| Re: wrong gasketDecember 2 2008 at 4:06 PM | Greg (Login GregMason) |
Response to Re: wrong gasket |
| I was wondering about the sealant on the head bolts myself. All the bolts should get RTV. The best thing would have been to put an radiator pressure tester, STANT or similar, on the heat exchanger and run the engine, if combustion pressure is escaping into a cooling jacket the gauge will build pressure. Of course the engine is apart now so magnufluxing the heads is your best angle. The manifolds could be rusted through causing the cylinder wall staining, etc. Is this boat in salt or fresh water? When you put it back together you can't beat FELPRO marine gaskets.
Greg |
