1958 Continental Claret -
Re: 1958 Continental Claret -
Your progress is impressive!
novetti
- Music instruments you're playing: Bass, Classical Guitar
Fine Gentleman and Ladies
Just uploaded this video a made a couple months ago when I had my brother visiting and helping out
Cheers
Julio
Cheers
Julio
That sure sounds nice!
Where did you get the vanes for the vacuum pump?
novetti
The Vanes in the pump were ok and reusable so I didn't need to source them. They are Fiber Phenolic material.
However if I needed, I would probably source a a Phenolic fiber board and cut my own vanes. Wouldn't be too difficult.
A quick search I found this.
My engine is back in place so I can't measure but I believe they were 1/4'' thick.
Garolite Micarta 1/4 thick
https://www.ebay.com/itm/Garolite-Micar ... 4d1715e87b
novetti
Lets put some movement in this Forum Gentleman
Some more photos from tasks I did in the last months.
Flexplate tooth with teeth very worn - most like from trying exceesively to crank the seized engine.
Fabricating from scratch rear wheel well panel sections.
Pressure regulator had a blown part from one of the valves. I sourced a replacement body for that.
What have you guys been doing?
Cheers
Cheers
novetti
More Panelwork / Fabrication Updates
Outer bottom rear rocker sections here - Both sides
