Mike I am not sure I haven't had one apart in a while. Looking at the data sheet from sherwood I think it is but one thing to note is the pulley is pressed on the D-05. But if I read this drawing right there is a snap ring on th back side of the shaft that may let the shaft comeout of the housing or at least let you get to the seal and bearings I presum it is leaking at the shaft?
If it is leaking somewhere else I need more information. |
