350Q 235hp timing mark - dimple to what RPM = 500?
May 31 2008 at 8:40 PM
  (no login)
Response to Q Timing
Do you set the "dimple" on the flywheel to the 500rpm as noted in the previously shown tech spec sheets?
I have a Snap on timing light that can adjust the flash in degrees no marks needed, that is as long as any knows what the "dimple" is i.e. 10 or 4 degrees BTDC.
thanks, Pete
