Advantage of running an aluminum flywheel?
Is there any advantage to running an aluminum flywheel on a 430? Won't a stock FE flywheel suit the need equally?
Re: Advantage of running an aluminum flywheel?
Welcome to the forum. A stock flywheel will do the job perfectly. I can see no reason why an aluminum flywheel would be superior.
Is there any product that you came across that you can link us, so we can get an impression of the alum. flywheel you consider to use?
An aluminum flywheel is used for competition engines due to less reciprocating weight and fast wind-up and requires a high RPM launch. A street car needs a metal flywheel for the stored inertia.
