FlyBridge problem
October 11 2008 at 4:19 PM
  (Login kwartler)
I had my boat transported up from Miami, to Jax. They took off the Flybridge. I have got it back in position but the plastic or rubber molding at the bottom edge is missing? Can anyone tell me if i can buy some or use something else? I have the steering and linkage all back on but i didnt want to fasten the flybridge until i checked with yall. Thanks in advance DAVID
Dave Mehl
There are a lot of extrusions that could be used
October 12 2008, 8:17 AM
I have seen posts here and info elsewhere in catalogs with a variety of vinyl extrusions that you could use. It all depends on the footprint you have between the FB and rooftop, as to which extrusion would work best. Naturally, the original extrusion would work best, but I doubt if they are available any more. There may be some similar extrusions that are being used today by other manufacturers tha do the same thing, so keep your eyes open.
Dave
Mike
Molding
October 13 2008, 5:24 AM
You did not mention what boat. If it is a 35 SC I have not been able to find anything after several years of searching. I have a dimensional drawing on my other computer if it is for the SC that may help. The bottom of the bridge fits flush, which is not possible, to the deck and does not have a flange like later years. The flange covers better.
(Login kwartler)
1969 CCC S.C/
October 13 2008, 7:09 PM
I found come weather stripping at lowes it seems to work and looks good. It sure was a pain to put it on though! Thanks for your reply. David.
Current Topic - FlyBridge problem
