Commander Cabin lights
September 24 2006 at 8:27 PM
Paul  (no login)
Many years ago I tossed the plastic cabin lights that were stock items from Chris Craft. I found a very nice "real glass lens" light with a stainless steel base, and these have graced TRADITION for years. Now I understand you can get this same light in a LED (light emitting diode) configuration. John Clemans, senior editor of Motor Boting Magazine, was the first one to tell me about this, and since then I've seen them for sale. The main benefit is the fact that a LED light burns very little electricity and it generates no heat. Therefore if you're out running on battery power without the gen set running, a LED lighting scheme won't drain down your battery for a very LONG time.
Since I believe details make the boat, here is a detail that we reconciled years ago. If you are still running the old milky plastic lens that came on the boat, it's time to change. Since LED fixtures are available that look identical to this, I recommend going the LED route.
While this light fixture uses the old fashioned heat producing bulb, it has a real glass lens, and the stainless steel case looks great. I recommend anyone who has not changed out their orignal lights to do so, because the upgrade is significant. If you do it now, go for the LED fixture that looks identical to this one!
Regards, Paul
FXA 38 3004 R
Echols, Howard
(Login HowardEchols38)
Where can I find this light with a LED bulb?
September 25 2006, 12:26 PM
They look great, and if I can find them in LED then that's a deal. I agree the LED bulbs draw so little power you could leave the lights on all day long and not drain the battery.
Those lights look good against the Commander headliner, and I really like the fact that they are "real glass" and not a plastic look alike.
Howard
Here's one source
September 25 2006, 12:37 PM
I have no idea about the price, I think you can find the same light at West Marine, etc., and it would pay to shop around. The price noted here seems pretty high.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4640773558&sspagename=STRK%3AMEWA%3AIT
Wes
Those do look great!
September 25 2006, 10:32 PM
Randy
Re: Those do look great!
March 18 2008, 6:21 PM
I outfitted my boat with all LED bulbs two years ago. They are plenty bright, they use just a small fraction of the electricity of the alternative bulbs. By doing so, we find we can run on battery power directly and through the inverter without having to use the gen set, and it is a safety feature if your battery can last longer.
RS
Additional cabin lighting information (photos)
September 26 2006, 4:29 AM
Here's an additional lighting thread that should be of interest to all Commander owners. http://www.network54.com/Forum/424840/message/1128231505
Here's the light in action!
September 26 2006, 5:35 AM
This light can articulate up out of the way and it looks much better than the plastic ships wheel and inverted dixie cup lamp shade that one of the previous owners had installed on the boat! Attentiion to detail is what makes a boat look good, and this is one way to do a really nice upgrade. Finding the light fixture was the hard part, because these things are apparently not a big sales item in lamp shops! A little epoxy on the bottom to hold the new studs in place, a hole to run the wire, and bingo!
Regards, Paul
Dave Mehl
My LED light reference information
March 19 2008, 8:20 PM
Interesting that this thread is back. I agree the LED lights can reduce battery consumption a lot, here is a thread with a reference to all the conversion bulbs you'll need to convert everything.
Dave
http://www.ledlight.com/?gclid=CJuBiaSTt48CFTaoGgodmzOUdQ
Current Topic - Commander Cabin lights
