| Original Message |
Paul (no login) Posted Jan 21, 2007 4:31 AM
Hello Scott,
To my knowledge, the "M" in this number stands for "mechanical". I do not believe there is anything "marine" about it, so proceed carefully. I would recommend calling Dan Cook for the marine product, unless you can find them elsewhere with the proper "USCG" designation, etc.
I purchased a pair of marine pumps from him a while back, and I can not remember if they have the relief ports to be plumbed back to the carb or not, because I have not installed them. They were purchased as spares at the time.
I do know the marine pumps I installed a few years back on a pair of 327F motors had the releif ports, and I went through the routine of running a sipll over hose from the fuel pump back to the carb.
If the m6905 is a street pump, as I suspect it is, it may not be built to the stringent safety standards required for marine pumps. It would be worth a call to Carter to verify this, for sure!
Regards, Paul
Regards, Paul |
