| Original Message |
Tom Slayton (no login) Posted Apr 21, 2008 8:31 AM
Thought this would make a nice addition to our archives.
Tom
W Series (WCFB) – (4 barrel) (1952 – 1965) metal tag; also code number stamped under base
AFB Series – (4 barrel) (1957 – 2001) metal tag: also some units stamped on edge of flange, some units stamped center of bowl in rear, some units stamped along bowl – airhorn seam in front, some units NOT stamped (tag only)
BBS Series - (identified by tag only, once the tag is removed, identification is extremely difficult
BBD Series - identified by tag only, once the tag is removed, identification is extremely difficult
YF Series (YF, YFA) - most O.E. carbs stamped with the number followed by letter ‘S’ on center section (bowl)
UT Series – identified by tag only, once the tag is removed, identification is extremely difficult
N Series (N, ND, NRD) – some stamped on edge of flange, others tagged
Carter numbering systems. Three different types of numbering systems are found on Carter produced carburetors.
(1) On carburetors built for Chrysler Corporation, a series of 3, 4, or 5 letters and numbers; i.e. EV1 or D6H2.
(2) On carburetors built for Ford Motor Company, the “Ford” numbering system which is “lnll – l(l)(l)” or letter, number, letter, letter dash letter (possible letter) (possible letter) i.e C5VF-A. This system is codified in that the first letter is the decade (B=1950’s, C=1960’s, etc.); the number is the last digit in the year; the 3rd and 4th letters (before the dash) represent the vehicle model (VF=Lincoln); and the letter or letters after the dash are a modifier which distinguishes the exact application. Thus in the example C5VF-A, the carburetor would have been the first application for Lincoln in the year 1965.
(3) The traditional Carter numbering system which consisted of 1, 2, 3, or 4 digits; followed by the letter “S”, possibly followed by another letter. It is extremely doubtful that any of the single, double, or early triple digit tags will appear; as they were produced before 1930 and were constructed of red cardboard. The metal tag appeared about 1930 with tag numbers of about 300s. The 4 digit tag appeared in 1952, and was continued on until the end. The letter S and following letters, when present, have caused much speculation (mostly incorrect). In Carter’s terminology, an individual part such as an idle mixture screw was a single part; whereas two or more individual parts sold together such as a needle, seat, and gasket were sold as an “assembly”. Carter used the suffix letter S to denote assembly. Since all carburetors are composed of multiple parts, the letter S was appended to all carburetors using the traditional numbering system i.e. 938s. If a significant engineering change was made to the carburetor, the letter “A” would be appended to the S (i.e. 938sa). A second change would have the letter A replaced by the letter B (i.,e. 938sb). The highest engineering change of which I am aware is 4 i.e.938sd. Contrary to popular belief, the S DID NOT mean standard transmission, nor the SA automatic transmission.
