| Original Message |
Tom Slayton (no login) Posted Feb 24, 2007 11:34 AM
In 1958 a new 283 block with thicker cylinder walls was introduced. These can be bored out to 4.0" when new (less if internally corroded badly).
This means the little 283 was one tough little motor with lots of iron. No wonder they last so long.
In 1959 rear main bearing seals were changed from graphite impregnated rope seals to a neoprene seal, far better design.
The 327 was produced from 1962 to 1967, according to the book, but the charts clearly show 327 motors in 1968 and 1969. Later in the book they say the 327 of 1968 usedthe large journal forged crank in most truck and Corvette applications, so I guess they acknowledge the 327 was produced beyond 1967. A lot of pattern changes were made at the factory to produce this one. Under side of the block was relieved so a bigger crank and 4" pistons could be used. On the 283 this operation would be required on most if you were doing a 4" bore job.
On one chart it shows the 350 starting production in 1967 and in another they say 1968.
For me, I'm old enough to remember that first 57 Chevy I rode in with the 283. Yes I know the 283 came out in '55. That 57 Chevy was considered a fast car back then, my how things have changed!
I see reference to mechanical solid lifters for the first six months of 283 production, and Corvettes up to 1964, the 327 fuel injection motors, and 1970-71 Z-28 motors.
From what I understand, Chris Craft started using the 283 in 1959, and there must still be many thousands out there still in service. Because of that heavy cylinder wall thickness, they can be rebuilt many times!
Cheers, Tom
