Re assembly
December 8 2008 at 7:53 PM
Eric Jensen  (no login)
Response to RiverDance
If memory serves correctly you have 427's in RiverDance. The pattern is middle top, middle bottom, move right of center 1 bolt, repeat top to bottom, then left of center top to bottom, then right end, then left end. Torque values are 1st pass 70 ft-lb second pass 80 ft-lb third pass 80-90 unless you have a 63 to 67 engine which ends at 100-110. BUT I would highly recommend that you buy Steve Christ's "Big Block Ford Engines" booklet before starting on the project. It's a good read and might just save you from making some big errors. Don't ask me how I know this.
Eric
