| cyl headNovember 18 2008 at 3:24 PM | Mark Weller (no login) |
Response to Cyl. head |
| What motor do you have? If it is a 427 it is not going to be cheap to replace if it is a sbc then what is the casting number there are a lot of different heads used on the sbc's. You will need to know what the casting number on the head is it is under the valve cover. Usually 6 to 8 digits like 333882 or 462624. Some heads can be repaired by welding depends on where the crack is and such you would need to take them to an expert for that decision. Good luck with whatever you decide. |
