| Environmental concernsOctober 30 2008 at 4:21 PM | Eric Jensen (no login) |
Response to Bilge bulkheads |
Although I could not find any requirement for it in the ABYC regs, a good reason to have the bulk heads under your engine is to contain engine fluids in the event of a spill. You did not say if there was a forward bulkhead as well to create a containment pond. Having been through an event where I lost most if not all of my engine oil, I can attest to the effectiveness of such an arrangement. Even if you were able to prevent oil or radiator fluid from being pumped over through the bilge pump, you would not want to chase the fluids the length and width of the bilge after a spill. Unfortunately the thing that makes a containment system effective are creating a problem for you because of that effectiveness, but that's your choice as far as what to do.
Just my .02
Eric
