Had good luck pulling hot coolant, (on a 350K) from the top outlet of the coolant circulation pump. Run a hose to the WH and a return hose to the thermostat housing...as the orig. hose was run.
I get VERY HOT water in about 15 min. after warm up. The one problem is regulating the high temp water as it leaves the heater...The shower can get a bit too toasty in unexpected spurts! |
