Air hole?
October 2 2008 at 10:21 AM
Paul  (no login)
Response to Comments please
If your strainer has an air bubble in it while the motor is running or not, it would appear to be that you have a small air hole in the line somewhere. The hole is small enough that when you fire up the motor the sea water pump will overcome the air hole and suck water and all appears well, but SOMEWHERE in your system, even at the pump perhaps, I'll bet you have a fitting that needs to be tightened up a bit.
It may also be you have an air bubble that is captured, and it needs to be vented. See if you can momentarily open a hose higher up on the system to vent that air bubble out, and then see if it comes back.
