Next step
September 7 2008 at 11:38 AM
Bill  (Login billinstuart)
Response to Can't see much of anything
Steve, after you power time it at 3/4 throttle, if ya got the cohones, you can do the same at full throttle. If the timing is all in by 3000, it should be the same, but that is the ultimate method. In practice, initial timing is set ONLY for convenience..what you're REALLY after is correct timing at cruise/full throttle.
You'll have to reset your idle settings after a timing change.
Good luck..lemme know what happens.
