Firing order
September 2 2008 at 7:15 AM
  (Login guyerst)
Response to Cap/Rotor and Timing
Thanks Rob.
We checked the firing order just to confirm. After getting through some confusion over which direction the motor is rotating in (original 327Q manifolds were reused and the manifold with the QL serial # was installed on the starboard motor - causing a "what the?" moment), we confirmed that the order is correct to the Q motor per my manual. Your comments make me wonder if the order is different on a Q motor vs the standard GM 350 order, which should I be setting up for since my original 327Q's have been replaced with GM 350's? I'll look up the firing order for a 350 here in a sec, but from what I can see the only difference is just the motor is "backwards".
