Next question
August 14 2008 at 8:43 AM
  (Login guyerst)
Response to Newbie with a couple quick questions (so far...)
Thanks all for the reply's.
Looks like I'll be learning carbs this off-season. I've been lurking here for a couple weeks, and have come across many great references for carbs.
How can I confirm if the parralleler(?) is functioning correctly? Checking with a meter, I can see voltage on either side that matches the corresponding battery. I'm guessing that the lower voltage side should see some movement when I have some one hold the switch? And if there is no change, is that my confirmation that the parralleler is not working?
Steve
