Hydraulic lifters
June 26 2008 at 7:16 PM
Greg  (Login GregMason)
Response to Welcome Aboard, Pancho
Hi Pancho,
The Chevy 454 stock, plain vanilla,marine engine uses hydraulic lifters, not solid lifters, therefore the valves adjust using the zero lash, plus another 3/4 of a turn tight. You would not adjust these valves with a feeler gauge. A good shop manual can explain it in better detail than I can here, but you can perform the adjustment with the engine not running, which is a lot less messy. You could have a lifter sticking but not necessarily out of adjustment in which case the top end lubricants might help. Some people use a quart of ATF to loosen them up, but I would agree that MMO would be better. There a lot of opinions about what home remedy works best. Has the engine been sitting unused for a long time? YOu could also have a cam lobe wearing out causing the excessive lash. Or you could have a valve sticking, which is the worst case because it will contact a piston top breaking stuff. Not good. Or the ticking could be something else entirely such as a wrist pin. Try killing ignition one wire/cylinder at a time and see if the noise changes pitch or goes away. A valve train noise generally would not change if you cancel the ignition on a cylinder.
At any rate do the simple things first, MMO in oil. Give it long enough time to get in there and work. Check compression to see if you have a low cylinder due to a stuck valve. Pull the valve covers and roll the starter with no ignition and carefully watch each valve looking for sticking valves or a valve not opening much or none.
Or do what a lot a people do. Ignore it until it blows!
Good luck, Greg
