Count the teeth?
June 7 2008 at 1:22 PM
Roy  (no login)
Response to Update on the Commander 23, need info.
I guess you count the teeth, measure the distance from centerline to outside of metal, and go hunting. Surely these things are out there on cars, because I doubt if that flywheel is for boats only, makes no senses at all for that.
Good luck on the hunt, I'm looking forward to seeing you back on the water with your Grandpappy's boat.
Roy
