427 t-stat
May 19 2008 at 6:36 AM
  (no login)
Response to vernatherm t-stats
David,
Are you sure your problem is the t-stat? I went throught the same issue a couple months ago. These t-stats are very well made and do not often fail. My problem turned out to be the guage which is wierd too. Are you getting water out of the top of the t-stat housing when she warms up? If so, yout t-stat is opening. If not, I would pull it and clean it up in CLR and test it in a pot of water on the stove. Mine looked brand new.....I am also in the DFW area, email me at trey.andrews@yahoo.com if you want.
