Galvanized supports
May 14 2008 at 4:12 PM
  (Premier Login FEfinaticP)
Forum Owner
Response to Update on hatches.
Hi Jerry,
We've following parallel pathways here, I discovered the same thing and installed a similar support on TRADITION at the rear hatch. Only problem, they stick down into the rear storage compartment, and you can slice the back of your head wide open if you get down there and encounter one of these knife sharp edges. I put a safety covering over mine, having had a pretty close call.
regards,
