Carb tip
April 21 2008 at 7:27 PM
Tim  (no login)
Response to Two styles of accelerator pumps
Paul,before you put your carbs on the engine,check the throttle butterfly`s for a "perfect wide open"position.Turn the carb upside down and then rotate the linkage to WOT and check the throttle vavles.They all should be at a 90 degree intersect with the carb base .
I have yet to see a perfect wide open setting on an OEM Chris Craft carb.
Tim
