yes that is correct it is just shifted a little but a circle is a circle as long as the order is the same it dont matter that cam should work fine the only difference may be lift and duration and I cant tell you that because I dont know the lift and duration of the cc cam. I wouldnt think the CC cam would be that much different if at all from what I know it seems they are pretty much stock marine cams and since you are a single engine I would just use the cam you got. |
