Vaporlock??
August 13 2006 at 8:02 PM
Anonymous  (no login)
Response to Thanks! I need som fuel delivery advice.
Are the lines running near the lower side of the manifold ports up front?? OR, Could you need to pump some more fresh air in there?? Just wondering if heat buildup is boiling the fuel at the pump?? Just a few thoughts to ponder. To rule it out, run her without any cowlings ( but you probably have already.)
