| How to determine flowJune 15 2006 at 10:31 AM | Paul (no login) |
Response to Re: Leak |
| if you could put something at a given test location that would be an indicator, that would tell which way water was migrating, then you could focus in on the location. Not sure I'd recommend food coloring in the water, but it would show a signature if water were flowing "from" the coloration. Naturally water will flow toward the bilge pumps, so in order to check the location of the inflow, you may have to shut off bilge pumps for a period of closely supervised time.
Just a crazy idea.
Paul |
