Lawrence, I looked at the article again and it uses the pressure pump inside the pan and what appears to be the scavenge pump outside driven off a gilmer belt from the crank. Now a question a little off this subject, when you run your booster line from the front of the engine to the back what size is it and do you leave the restrctor in the left side of that main or do you eliminate it?
