I've used that distributor on my SOHC with good results. It's true that the bulges for the hold down in the cap prevent free rotation of the distributor, but I was able to get about 30-35 degrees rotation, which was enough to start and time the engine successfully.
Sounds to me like your water temperature sender is the hold up. Can you relocate it to a different spot and plug the hole? That should let the distributor rotate a little more, hopefully giving you the timing adjustment you need...
Jay Brown
