In your text you wrote:
NOTE: For owners with a manual transmition (dry pressure plate) and rear diffrential drive. I would recommend not adding the transmission fluid to the differential oil. The packaging does not directly address this issue. I believe there is a danger of increasing small leaks or seal seaps by using this product in the differential oil.
I have a 1995 Nissan Altima, with a 5sp. manual transmission, do you think that the trans. fluid would hurt mine????
