On a few forums I visit, links are no longer working properly. I'm hoping it's a glitch that will repair itself, but in case you are unaware, there is a problem.....
Would you post the actual code you're using here with formatted text checked off? That way I can test the code on our dev site and see about getting it working again.
Chris Moser network54.com
Ok, I just sent out a fix that should get your signature working again. It should fix issues with other signatures as well. Let me know if it works for you!
I just checked and some of the formatted signatures on my forum are still showing the code in them. Mine appears to be working now, but others are still having problems.
(Premier Login homeskillet) Network54 Premier Admin Group 63.224.4.198 Qwest Communications Minneapolis, MN United States
Ours are still very messed up! Please help!
November 6 2008, 6:39 AM
It's very frustrating and distracting and we are on the third day of a bunch of mumbo jumbo in the posts. Many signatures are showing up as tags, as are emoticons.
