without knowing all the details, but it's possible that Network54 changed something, or it's possible that Photobucket changed something, or it's possible that neither changed anything, but it got changed at the server level, which really complicates things even further.
I'll give you an example. I manage several websites, most on the same server. I use PHP ( a form of HTML that uses server side scripts to do things that would require much more code if it weren't used). I also manage some sites on other servers. Some of those sites cannot use PHP and some of them can, but it reacts differently than the PHP on my server. I can copy and paste code that works perfectly on my server to that server and it has all kinds of errors and glitches on that server, although, according to the host, it should work the same way... It doesn't.
I won't even start on ASP....... It's similar to PHP, but it's different enough to be completely confusing when trying to figure out why things aren't working....
Then we get to HTML standards..... Just putting the type of HTML in the page's header can cause problems if the standards are not adhered to within the code....
Then there are browser compatibility issues. It's enough to make you pull your hair out.
RipperŪ - Long Island Customs150 Thorburn Ave
Lindenhurst, NY 11757
631-422-0408
Network54 Forum Tech Tips
