Can't figure out what you mean. Will you please re-phrase?
Tree
Re: brake light
July 13 2005, 1:46 AM
Did you check your brake fluid level in the reservoir ? If it is OK, you need to have other hydraulic and electrical components by a technician.
Bewildered Mazda Owner
Re: brake light
July 15 2005, 3:41 AM
You may have low brake fluid, the brake fluid could be dirty and the sensor for low fluid is reading falsely due to the dirty fluid. Water in the brake fluid will also cause this. If the fluid in the reservoir is dark colored it is dirty and has gotten moisture in it. Brake fluid is like a water magnet. And it is not a good thing if it gets water in it. A minicule amount of moisture can cause havoc.
