You can try a product such as this one (http://www.por15.com/) to stop the rust, then apply a patch over the hole. Or you can cut out the rusted area, prime it with a rust resistant primer, then apply a patch. An auto body shop can also give you options.
Got Welder
March 19 2005, 1:55 PM
The best way to repair an area such as this is to find some sheet metal approximately the same gauge. Cut out a square or retangular piece that is a little larger than the hole. If the area is curved then shape the piece. Now weld it in place. If you or a friend don't have a welder then call around. Most small weld shops will do this job for $10-25. It will take them all of 2-3 minutes. Grind area smooth and body fill (if needed). Now spray some primer and paint on it and you ready to go.
bzl
Re: fuckin rust
March 22 2005, 9:14 PM
it wasnt a hole in the trunk door, it was between the rubber trunk seal and the body, the part that the trunk door covers up.i dont get how it got there, its a florida car. i ended up using that rubber kitchen and bathroom sealer that comes in those caulk tubes, and that sealed it up perfectly.
Re: fuckin rust
March 23 2005, 1:43 AM
I doubt that your repair will hold up permanently if the hole was caused by rust. Good luck. though.
1988 323 LX Owner
Fucking rust
October 15 2005, 4:52 PM
Florida air is salty, and salt is the mother of all the means to make a car turn to rotting metal...
Take it from someone living in a country where they spill tons of salt on the roads yearly, to get the ice to melt in winter... It does wonders on destroying bodywork!
I was amazed to see that my 1988 323 had very little rust in 1999 (when I got it, virtually none outside, just inside a rear door), but I'm now at the point where reconstructive esthetic surgery is a must, if only to keep the safety patrol's attention away from the car (holes in doors and the such are a big indication that maybe the mechanical side of the car's on the go too)
Re: fuckin rust
November 21 2005, 7:53 PM
One good way to fix a small hole in a trunk is to use fiberglass cloth soaked in resin. buy a fiberglass repair kit at Autp zone or other part store for about $ 12. Then use supplied screen mesh as backing and follow instructions on mixing the resin with hardener. Then soak the pre-cut fiberglass cloth in resin and apply over the mesh over the hole. You can apply several layers. I performed a repair like this on an older car and it turned out great.
