battery discharging
November 23 2004 at 4:48 PM
i have a 1997 madza protege-after several days the battery will be so weak it want start the car.-had battery checked and it is good,no dead cells,-alternator checks good,with lights and heater on the voltage is over 14volts.--the starter and solenoid are good-there must be a shortage some place,,maybe someone there has a similar problem that could give me some info.--ray
battery discharging
November 23 2004, 8:02 PM
A good place to start is to hoook up a multi meter to the battery and remove one fuse at a time. When the battery voltage goes up you know that there is a drain. Some fuses such as one for radio, alarm and those type of systems will always have a slight drain.
Re: battery discharging
November 24 2004, 4:52 PM
Also check the following technical service bulletins: G00197. G00198, and G00396.
Current Topic - battery discharging  Respond to this message
