question b2200
July 28 2004 at 5:48 PM
got a question. I need higher rear dif. gears for a mazda b2200 who would sell them?
peter
diesel?
July 29 2004, 6:28 AM
How about a diff out of the diesel version? Don't know where you would find one, but I'm guessing it would drop right in.
Rear End Gears
August 1 2004, 3:53 PM
Actually the diesel I think either has the same or lower gears than the stock gas B2200. I do know for a fact that you can't just unbolt the ring/pinion assembly and bolt it into another, if they are different you must remove the gears and reassemble them in the B2200 housing. If you don't know how to adjust it right you can really skrew up your rear end. All of the 4x4s run a 4.44 rear end. The trucks have the lowest gear ratios of all the mazda's so unfortunatly your options are very limited, especially if you want to do it cheap or easy.
www.mazdatrucking.com
Current Topic - question b2200  Respond to this message
