overheating
June 21 2004 at 2:22 PM
i just both a mazda mpv 6V 1991 and the engine overheating -go to red.
It could be the thermostat ??///--or something else.
thank
overheating
June 21 2004, 11:53 PM
First things to check are the themostat and radiator cap, both cheap replacements. If that doesn't fix your problem you'll need to run some test. If your not sure how to do that take it to a shop. I would think it should'nt cost over $100 US. Other possible causes of overheating, clogged radiator, failed water pump, blown head gasket, and cracked head. Good luck.
Current Topic - overheating  Respond to this message
