Did you not ask for programming instructions from the seller? Most on eBay will provide that data. Not sure about a 1995 model but programming keyless remotes can be a little hairy when you are reading the instructions for the first time. They sound like something out of Harry Potter. Dealers often re program for nothing if you are a regular customer of the shop but some do charge $75 or more. Also be aware that if you already have one or more remotes and want to program a second or third remote then you must re program both or all three. The original remote that was working just fine will no longer work after performing the programming for just the "new" one. The new one will now work but the original will not. Go figger. Reply to this same posting with the model number on the back of the new remote and make sure it is the same model number as the original if you already have one. I have provided progamming instructions in several postings here some weeks ago but since there is no search program on this site (unless you pay to become a member) I suggest you scroll back 5 or 6 pages and read the headings.
Sailmaker
Re: keyless entry
August 30 2003, 11:11 AM
I can see you are really anxious to get the progamming procedure. Why do people like you come here to get free advice then disappear back into your hole?
Re: keyless entry
August 30 2003, 3:10 PM
The following was posted some time ago. I don't remember the poster, but what have you got to lose?
1. Close all doors.
2. Open drivers side door.
3. Place key in ignition.
4. Next three steps must be done in under 30 seconds.
5. Move key to on and back to lock 3 times.
6. Remove ignition key.
7. Press drivers side door lock button three times.
8. Test the door lock button and make sure they still work.
9. Press any button on the transmitter twice.
If it works then thats it. If not repeat the procedure.
FCC#
August 14 2004, 1:40 AM
Are you sure you have the right remote for your car?
I also am looking into purchasing 2 keyless remote from E-BAY but want to be SURE
that the KFU41048 will work on ALL 2000 Millenia's
If it works on your car please RSVP me with results.
OR If anyone else knows the answer
THANK YOU
Programming Stepd
August 21 2004, 6:14 PM
Step 1: Open the driver's side door, and then press the lock button (on the door) so all the doors lock and the security light comes on.
Step 2: Unlock the drivers side door by turning up the MANUAL Un-Lock switch on the door so the security light now turns off.
Step 3: Insert your key in the ignition and turn it to ACC position, and then take out the key. Repeat this two times. (remember to take the key completely out!) For a total of THREE times.
Step 4: Press the Door Switch THREE times. This switch is located on the door jam.
(BE SURE THE DOME OR DOOR COURTISY LIGHT GOES OUT WITH EACH DEPRESSION OF THE SWITCH)
The car should now beep once.
Step 5: Press any button on the remote. The car should beep once again.
Step 6: Repeat STEP 5 till ALL the remotes you have/want programed.
Step 7: Wait about 5 seconds and then the car should beep four times.
Step 8: Press the Un-Lock button (on the door) and NOW your remote is programmed!
Step 9: TEST ALL KEY FOBS FOR PROPER PROGRAMMING AND FUNCTIONALITY.
Step 10: Pay me $20.00 for these programming steps ROFL
