December 22 2002 at 10:30 PM No score for this post
Timi Gina
Hi I have a Mazda MX6 that is 1995. When I am not driving and it is in gear and not in parking it vibrates. What could this be. Please someone tell me if this is bad or normal. Thank You.
hey well i had mazda befor and in the cold weather the vibrations is normal in the summer it all good but check ur spark plugs if there bad or not
Re: Vibrations
January 16 2003, 1:35 PM
could it be a bad engine or trans mount???
i have the same problem!
December 16 2005, 4:55 AM
hi dude, look i have a mazda lantis 1996 1800cc automatic, when its on the "p" its marvelous very quite, but only when i move it to the "d" it has small vibrations, but the problem is when i turn on the air conditioning, u can feel that these vibrations become stronger & u can also see that the stearing is vibrating too! i u fixed ur problem can u help to fix mine?! thanx man!
December 16 2005, 4:57 AM
hi dude, look i have a mazda lantis 1996 1800cc automatic, when its on the "p" its marvelous very quite, but only when i move it to the "d" it has small vibrations, but the problem is when i turn on the air conditioning, u can feel that these vibrations become stronger & u can also see that the stearing is vibrating too! if u found a solution to ur problem can u help to fix mine?! thanx man!
Re: Vibrations
December 21 2005, 8:32 PM
This can typically be motor mounts or the state of the engine tune. I'd live with it unless it was real bad, in which case I'd take it to a Mazda mechanic.
