Check Engine
July 29 2002 at 7:55 AM
I was driving 60-70MPH in my Mazda and I saw "Check Engine" light comes on. It was on for several miles then the light turned it self off "Whoof"! I wonder what could that be? Has anyone encountered this error before?
Re: Check Engine
July 31 2002, 12:24 PM
Could be oxygen sensors or Knok Sensors.
Re: Check Engine
July 31 2002, 12:25 PM
merlin
Re: Check Engine
July 31 2002, 2:35 PM
It could be a dwarf living in your air cleaner and farting into the intake causing electrical malfunction.
Check Engine
August 4 2002, 10:04 PM
If the engine check lights light is caused by Oxygen sensors, would this mean I need a new one? Is that something like pre-failure? Because the lights does not come on at city driving. (whew).
All Indications towards O2 sensor
August 5 2002, 8:11 PM
Spoke to my mechanic and he is 80% sure it's the O2 sensor. Have you changed yours yet. I will work on replacing this weekend. Going to Mazda Recycling in Rancho Cordova, CA. They have cheap stuff.....
ENGINE LIGHT !!!
August 6 2002, 2:08 AM
i had my engine light come on too, then spent $500 to replace "faulty" O2 sensors. and whaddaya know, the light came back on about an hour after i drove it out of the auto shop. i keep coming back to have the mechanic figure out whats going on....as of this writing its still up in the air.... he tried different things and keeps resetting the light. however it just comes back on and on and on.
my idling is really weird now... kind of makes a 'cycling' sound (like a washing machine) and i sometimes get pinging during acceleration (even with the highest octane "supreme" gas from Chevron)
anyone having the same problems and want to compare notes feel free to email me
ld_consultant@yahoo.com
Shaun
Light
August 6 2002, 5:23 PM
Put your hand up behind the dash board and rip out the light, Problem solved!
Dody
Re: Check Engine
August 7 2002, 12:00 AM
I got the same problem with you and completely knew what the problem was when I failed the emission test.
My car had too much CO.
I finally spent $450 to replace 2 oxygen censors......
626 ES V6
Re: Check Engine
August 7 2002, 12:44 AM
Dody, so now your light is off ? and you passed emissions?
check engine light!!
June 6 2005, 5:51 PM
ok i have an 00 milennia s and the check engine light keeps coming on and off whenever she pleases... the ppl where i bought my car told me it had something to do with the feul b/c the man that filled it up did it while the engine was on (*i know im a chick but damn.. what kind of machanics did they hire???*) so i gave it a week a filled it up with super and it cut off... when i got to a half of a tank it cut back on again.. so i put fuel treatment in and it cut off then... well you know the damn lights back on and wont cut off again! and like that isnt enough there is a thumping noise that sounds like its coming from my left tire and gets louder when i turn or take a curve one way... can someone help me b/c the machanics over there wont!
Dave
Knocking
June 6 2005, 8:06 PM
This is to Stacy. In reference to the knocking sound coming from the tire when you turn a certain way it is the C.V. joint. Whenever they are worn out they will make a knock or clunking noise depending on the way you turn. But the check engine light, there is a way to reset the computer in the car that might help. Take the ground wire off of the battery for 15-20 seconds. That causes the computer to go into reset mode. Hope that helps.
Stacy
Re: Check Engine
June 8 2005, 6:57 PM
well they reset the light plenty of times before.. it still keeps coming on.. and im not sure if its the cv joints b/c of the type of sound.. it even does it lightly when i am just going straight but worst when i turn right mainly on big curves. does this sound familar?
check engine
August 1 2005, 12:45 PM
We have a 99 S model and have 67k on the car, bought new. Just went thru the 60k maint, $1600.00. Car went in to shop last week with the red light, something about vacum hose and something else like fuel system cleaning. Well it's back 4 days later. I am blaming myself for buying this car and now wish I had stayed with Honda, never had these issues and expenses....
Current Topic - Check Engine  Respond to this message
