| as Angelo says... andOctober 24 2008 at 1:40 PM | Myron Samila |
Response to Re: custom fabrication? |
| unless you're doing engine work to it, what's the goal?
It's a lot of work to swap it, for a small amount of gain. You can easily do some mods to the 1300/1500 engines that will see a power increase, however, if you do plan on upgrading the twin cam, then you'll see even bigger benefits.
| Responses |
