Boss 351 crankshaft?
December 27 2008 at 3:55 AM
AJ  (Login 71grr)
from IP address 71.71.195.186
I finally got around to looking at the old crankshaft that came out of my 393 stroker, and noticed it has a 4MA casting mark on it. I thought all the "regular" ones just had 4M. Is this a Boss crank?
tinman
(Login tinman351)
maybe Blizz has a pic?
December 27 2008, 8:54 AM
4MA is a revised production crank, Boss cranks have a number starting with "D1ZX" i believe it is? electric pencil etched at the rear of the crank.
"Enlightened statesmen will not always be at the helm" ~ James Madison
joe
(Login methylated)
Moderator
4.154.6.215
The D1ZX was cast in
December 27 2008, 9:54 AM
I've held one in my hot little hands !
tinman
(Login tinman351)
Re: The D1ZX was cast in
December 27 2008, 11:15 AM
what was it then that was electro-graved in?
Randy
(Login gt350hr)
D1ZX-A was...
December 27 2008, 7:28 PM
hand stamped on a couuterweight near the front (#3 maybe). Those that passed the Brinell Hardness test were stamped. A Brinell hardness tester is
a specialty machine that non destructively tests metal hardness, The machine
has a screw jack that "adjusts" a probe to a "0" point on a pressure dial. A
lever that trips a timed release of pressure on the probe. A tattle tale on the pressure dial tells you what the hardness was/is. More exotic versions are digital and give a digital readout. There are many different tip daimeters on the probes for different metals. There are also at least 3 different scales used in hardness testing. A is seldom used, B is used for aluminum and others, while C is typically used for steels and iron.
Cranks without the D1ZX-A that have the domple simply weren't hard enough
for the D1ZX-A specification and weren't stamped.
Randy
(Login 391locker)
Re: Boss 351 crankshaft?
December 27 2008, 11:20 AM
IIRC, the boss cranks were just 4MA cranks that tested as having better than average hardness......nothing I'd pay extra for, especially considering the relatively low cost of 4340 cranks these days.
tinman
(Login tinman351)
December 27 2008, 2:08 PM
many cranks were tested to qualify at spec, not all tested were assembled into Boss engines. my first Clev had the test mark in a 2V.
AJ
(Login 71grr)
What does the test mark look like?
December 27 2008, 2:26 PM
And where is it?
lawrence coppola
(Login L.A.racing)
4MA B
December 27 2008, 2:47 PM
so what was the 4MA B crank?i have seen them with a small m/c pad near the number on the front c/w ,and have seen what looks like a brinell ballbearing mark on this small pad . is this anything?
tinman
(Login tinman351)
IIRC
December 27 2008, 2:56 PM
it's a small spot ground smooth on the front counterweight?
with a center punch looking indentation in it. the diameter of the punch mark indicates the resistance or hardness of the metal when compared to the test scale.
http://www.instron.us/wa/applications/test_types/hardness/brinell.aspx?ref=http://search.yahoo.com/search;_ylt=AgUOPlMLc9eiUGDNsN8nYOimN3wV
(Login L.A.racing)
Re: IIRC
December 27 2008, 3:22 PM
so It is a brinell mark. but what is the "B"
tinman
(Login tinman351)
what's the B
December 27 2008, 3:27 PM
it's a further production revision
(Login fomocoBw)
An old Ford parts guy once told me it was simply refering to "brinell"
December 27 2008, 4:41 PM
n/m
joe
(Login methylated)
Moderator
4.88.14.75
they probably cast D1ZX in it because
December 27 2008, 5:06 PM
It used a nodular flywheel and unique damper . the boss had 27.3 oz-in imbalance as opposed to the normal 28.2 . that likely explains the DIZX scratched in the back of the block as well ,so the assembly line personnel would know what to stick in it .
DragBoss
(Login DragBoss)
Re: they probably cast D1ZX in it because
December 27 2008, 5:31 PM
I have one, or that what I ws told, I know it had a Brinell mark, will take a pic, also have matching dampner. I do not remember any D1ZX numbers, will ck.....Tim
Current Topic - Boss 351 crankshaft?
