Re: lateral thinking
December 27 2008 at 9:29 AM
  (Login tony-can-do)
from IP address 75.154.110.177
Response to Re: lateral thinking
I got my block back from the shop as well and all the lifter bores are bushed as well ,I am not sure what size the metering hole is they were in when I purchased the block.is there a standard size metering hole put in the bushings and should I be leaving out the rear main restrictor as well.
Thanks:Tony
