C6 trans questions
alternate
Editorial Group
Editorial Group
C6 trans questions
Post by alternate » Sat 9. Oct 2010, 12:43
Note: Complete or part of old conversation copied from the archives and brought back to you by admin. The line below shows the original date of the post. New replies can be added if desired.
_____________________________________________________
Originally postet by "bigwillis "
April 19 2005 at 6:44 AM
from IP address 70.177.237.243
i have a 77 ford f-100 with a 462 from a 66 lincoln in it. is the trans just a standard C6 or is it unique to these engines? having problems with mine and just not sure if i should just rebuild or replace. thanks
Re: C6 trans questions
Post by KULTULZ » Sat 9. Oct 2010, 12:44
462 C6
The main case/mounting bell was unique to the 462.
alternate
Editorial Group
Editorial Group
Post by alternate » Sat 9. Oct 2010, 12:46
compatible parts
are parts for the ford c6 (such as rebuild kits, torque converter, pans) compatible with my c6? it seems hard to find anything specifically for the 66 462 trans
Post by KULTULZ » Sat 9. Oct 2010, 12:47
Maybe?
I believe the MEL C6 is almost identical to the regular C6 other than the main case, and that only differing on the bolt pattern to the block.
Is it possible you have a TWIN-TURBO? Is the bell and main case one piece (aluminum) or two separate pieces? Do you see a metal assembly I.D. tag on the servo cover?
430 6V
Post by 430 6V » Fri 11. Feb 2011, 17:25
I know this is an old thread, but just for future reference.
The trans is the same as any other early C6 except, the case, tailhousing and output shaft are unique. Case for bolt pattern, tailhousing for mount and three spline yolk with linear bearings.
The tailhousing and output are a direct swap to any other C6.
Also original lincoln forward clutch friction plates are a coarse spline as are other early C6 units. This is easily updated to the later fine spline by using a later input planet internal gear.
Return to “MEL Transmission”
