1960 430 and 462 parts interchange
Posted: Sun 29. May 2011, 08:14
I just.got a 1960 430 and was wondering which parts off a 64 and 67 462 will fit on it. I learned that MEL engines after 1960 do not allow using FE bellhousing, and stick trans. I have to use 58-60 block so I can runT85 trans. Can you guru's tell me which parts from the 462's will fit on the 430? Cam's the same? What would you use from 462 if just doing a cleanup and run or what 462 parts would you use if engine requires rebuild?
