overly high compresion psi
Posted: Tue 13. Apr 2010, 03:51
Hello , i am new to this forum so hey to all out there. I am helping(working for)a friend to restore his 1962 Lincoln and i am having trouble figuring out why the 430 has 230+ psi when doing a comp check.
Let me first state that the car was purchased with a fresh rebuilt motor so i am dealing with a unknown as far as what was really done. The very first thing i do with any engine is check cranking comp and this motor came up all even,but very high in the 230 psi+- 5psi.
The owner told me he was having major trouble restarting the engine after it reached operating temp and that it would rattle under any kind of load. After trying to get it to run by pulling the dist timing way back (like to 4 after TDC) it ran a little better but was eating gas and still rattled a bit. What my brain told me was who ever put it together must have missed the valve timing by a tooth or the timing gears were not indexed properly at the factory. Well to my amazement the cam was lined up fine as far as the timing marks were concerned.
The next thing i did was get my degree wheel and 1in dial indicator out and check what was there.
The only reference i had was an intake opening of 22 BTDC in an old Mitchell Motors manual. i checked most of the cam manufactures and none listed the MEL specs but most of the stock/oe timing of similar size engines of the time spected out from:
Intake Valve Opening @ 18-24 BTDC
Intake Valve Closing @ 55-65 ABDC IC @.006
Exhaust Valve Opening @ 55-65 BBDC
Exhaust Valve Closing @ 18-24 ATDC
It seems a reasonable total around 250 degrees or so. What i came up with was very close but a little shorter with
Intake Valve Opening @ 16 BTDC
Intake Valve Closing @ 55 ABDC .........@.006
i also checked at .050 and came up with
Intake Valve Opening @ 13 BTDC
Intake Valve Closing @ 28 ABDC
wich is very close to the specs given on this site.
On the exhuast i got
Exhaust Valve Opening @ 32 BBDC
Exhaust Valve Closing @ 13 ATDC
and that seemed close enough for the valve timing to be acceptable what gives ?
Why is this thing got so much cranking psi (stock is kinda high at 180psi)?
Even if it has .030 or .040+ bores and pistons that still should keep the static comp below 10.5 (stock 10.0). Also the builder left out the oil galley plug in front of the distributer. So what else could he have done wrong?
One last thing is i believe the exhaust valve timing listed in this forum is at .006 and not .050.
Like the intake listed above 258 is a bit long @.050 but just about right for total duration@.006). My figures on this cam show it to be a little worn at 248 in and 250 ex @.006 and 192 in and 202 ex @.050 and lobe lift total of .240 (down .010 from spec) the cam is correct with a ^(triangle casting before the last cam brg)
Any ideas why there is 50+psi over stock(180) ?
I am going to buy a new cam for it but if stock is only giving me 10 more deg duration i might have to have a cam ground a little longer yet to bleed off some low speed psi so this thing can be driven by the owner. Thanks for reading this and any info at all would be very appreciated DjGriff
