Engine Oil Pressure
Posted: Mon 17. Mar 2014, 16:09
Well we got the new engine rebuild up and running. Seems to idle fine and after some tweaking of the timing we got it pretty much dead on at 6 degrees advanced. I do have one major concern however. On initial startup the engine seemed to have consistent oil pressure at around 40 pounds at idle but after running it for about 15 minutes up and down the rpm band the pressure dropped to 20 pounds at idle (800 rpm). The oil pressure does rise to around 45 lbs at 2000 rpm but it seems to me that 20 lbs is low at idle or maybe I'm just being a worry wart. The shop book says 35-55 lbs at 2000 rpm is normal but mentions nothing about idle.
On another note the shop book says the cold cranking cylinder pressure should be 180 lbs. Our maximum on ALL of the cylinders was 120 lbs on each one evenly when cold. I do realize that the new rings probably aren't seated yet but I guess I just want to hear someone tell me what their experiences have been with oil pressure and cylinder compression.
