Tips for sending heads to the machine shop?
Posted: Sun 6. Jan 2013, 18:29
Hi everyone,
I disassembled a set of heads out of a 64 that I'm planning to send to the machine shop when I found a couple problems. I've never really worked with a machine shop, so I don't know what exactly to have done. Right now, I was just thinking getting them cleaned, new valve seats, and the intake and exhaust surfaces straightened. And have them take care of the two problems below:
First problem was a couple mushroomed valve stems. The first valve I just pulled like hell to get it out and realized it scratched the guide on its way out. Anybody know how much a that mistake just cost me, or if it even needs to be fixed? The second mushroomed valve I filed down, so I'm hoping to be able to pull a couple valves out of the set of heads on the car right now and use them instead.
Second problem is one of the heads is cracked right above one of the exhaust manifold stud holes. I'm guessing it can be welded, but again, is it gonna be expensive?
These are spare heads that I was planning to swap into my car, so if this is going to be something I need a second mortgage for, I might as well just scrap em.
Took pics on my phone but the scratches or the crack didn't turn out.
Let me know your thoughts!
Thanks,
Pat
Thanks,
Pat
