tri power
alvin
tri power
Post by alvin » Sat 19. Mar 2016, 15:19
looking for a original fuel pump top for the tri power set up, i have a reproduction one thanks
Re: tri power
Post by 59lincolnrag » Sat 20. May 2017, 04:29
That part is not available. However its basically the same pump with that special 3-port outlet. Somehow I remember the pressure is 7 lb instead of 4 lbs. So maybe the spring or the stroke or the push rod is different.
